S1500 and IAP integration Document
  • 1.  S1500 and IAP integration Document
    Posted Feb 06, 2014 05:45 AM
    Anyone have the integration document or writeup on integration between S1500 and IAPs?
  • 2.  RE: S1500 and IAP integration Document
    Posted Feb 06, 2014 06:39 AM
    Refer to 7.3 MAS user-guide doc, "Chapter 38 Aruba AP Integration"
    if you don;t have that doc, same can be download from aruba support site:
        http://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Default.aspx?EntryId=12270
    -Vinay
  • 3.  RE: S1500 and IAP integration Document
    Posted Feb 06, 2014 07:45 AM
  • 4.  RE: S1500 and IAP integration Document
    Posted Feb 06, 2014 07:40 PM
    Thanks Vinay and Tim. Real easy to get things done withj all the experts here.
