Virtual Controller DHCP DNS setting Question
  • 1.  Virtual Controller DHCP DNS setting Question
    Posted Jul 26, 2018 12:00 PM
    Currently have 2 DNS servers listed for the built in virtual controller DHCP server. I would like to remove these so the guest SSID's use the internal DNS server configured on the AP's. If i remove these and click apply...does anything restart? AP's, VC, etc? Or is it seemless and applies on the fly without any sort of resets?
  • 2.  RE: Virtual Controller DHCP DNS setting Question
    MVP
    Posted Aug 10, 2018 10:36 PM
    DHCP only comes into play on initial connections and after an address is acquired, any changes to the DHCP shouldn't affect existing users. That being said, I would still do this after hours to be safe, as you don't know how clients may react, but I would say I'm 95% confident it would not affect anybody users already on.
  • 3.  RE: Virtual Controller DHCP DNS setting Question
    Posted Aug 12, 2018 05:16 PM
    No any changes in the DNS or DHCP doesn't require a reboot.
    Cheers,
    Lokesh G
  • 4.  RE: Virtual Controller DHCP DNS setting Question
    Posted Aug 13, 2018 07:57 AM
    thanks
