Virtual Controller over L3?
  • 1.  Virtual Controller over L3?
    Posted Oct 03, 2014 04:46 AM
    I've been looking through various documents and these boards and I am getting the general impression that the IAPs cannot be configured to connect to an IAP acting as a Virtual Controller over a layer 3 boundary. Is someone in a position to confirm that? If it is possible, does anyone know of a document which describes the process / requirements?
    Thanks in advanced..
    Bksy
  • 2.  RE: Virtual Controller over L3?
    Posted Oct 03, 2014 06:20 AM
    Correct. They need to be in the same subnet. If you need to cross boundaries, create multiple clusters.
  • 3.  RE: Virtual Controller over L3?
    Posted Oct 03, 2014 06:25 AM
    Thanks for your help.
    Bksy
