What power gain should I set the ANT 3 x 3-5712 for, when connected to the IAP 274.
  • 1.  What power gain should I set the ANT 3 x 3-5712 for, when connected to the IAP 274.
    Posted Jul 10, 2015 11:07 AM
    What are the power gain settings for the 2.4 a 5 Gig radio channels when connected to IAP 274 access points.
  • 2.  RE: What power gain should I set the ANT 3 x 3-5712 for, when connected to the IAP 274.
    Posted Jul 10, 2015 12:02 PM
    That antenna is only for 5GHz band.  The max gain is 11.5 dBi.
    http://www.arubanetworks.com/assets/ds/ap_ANT-3x3-5712.pdf
