- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Wired Profiles
Wired Profiles
08-22-2013 08:24 AM
Hello, I am fairly new to Aruba, and I am wondering what is the Wired Network Profile used for?
Does my eth0/0 port need to be configured with a wired profile? This is the only port I use, it is defined as a trunk port on the connected dell switch.
I have a data VLAN that the IAP's are IP addressed within and this is defined on the System settings.
I have 2 SSID's each on their own VLAN as well.
I ask because my two IAP's keep appearing as master when I log into the virtual controller, then I get kicked out, once logged back in the other IAP is the master.
Thanks for your help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
Re: Wired Profiles
Re: Wired Profiles
08-27-2013 05:37 AM
Hi JimJones,
The wired port profile is used to configure how the wired port on your IAP behaves. By default it's set as an access port. You can also configure it in trunk mode and set a default VLAN and allowed VLANs which it sounds like you'll need to do.
Can you let me know what VLAN and IP each IAP has been assigned?
Cheers
James
Cheers
James
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
Re: Wired Profiles
Re: Wired Profiles
08-27-2013 07:32 AM
Hi James.
Both IAP's are setup to be managed in VLAN 2,
IAP1: 172.18.24.220
IAP2: 172.18.24.221
Virtual Controller: 172.18.24.222
Then we have two SSID's one using VLAN 6, the other VLAN 100.
I have set the wired profile to a trunk port, with the native VLAN set as 2, and allowing 'all' VLANs.
I decided to reset one IAP and now it will not join to the Virtual Controller already on the network, so I now have two standalone IAP's, not ideal but it is working. I have a feeling we have a layer 2 issue, because both IAP's are on the same country code and auto join is definetely enabled at the GUI.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
Re: Wired Profiles
Re: Wired Profiles
08-27-2013 07:42 AM
I'd setup the wired ap profile like so.
Mode: Trunk
Allowed VLANs: 6,100
Native VLAN: 2
Disclaimer: Backup your config! Test this on one of your APs to ensure it behaves as desired.
Cheers
James
Cheers
James
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
