ap 92 radio is not turning on and due not able to configure ap please help power light is blinking
  • 1.  ap 92 radio is not turning on and due not able to configure ap please help power light is blinking
    Posted Feb 05, 2015 05:06 PM
    I am trying to configure ap 92 but radio light is not turning on and due to that I am not able to connect Instant network . Ap 92 connected with external antenna kit 19
  • 2.  RE: ap 92 radio is not turning on and due not able to configure ap please help power light is blinking
    Posted Feb 06, 2015 05:13 AM
    Are you trying to deploy IAP or AP ? if it is AP, what are you seeing under flags when you use " show ap database " or can you share the output of " show ap database" and "show ap active"
    Please feel free for any further help on this.
  • 3.  RE: ap 92 radio is not turning on and due not able to configure ap please help power light is blinking
    Posted Feb 06, 2015 12:36 PM
    I just got new ap -92 And ap 93 it's very easy to configure ap-93 by using wireless via connecting Instant but in 93 model I am not able to connect instant means I am not showing Ssid instant so I can connect with it and configure
    Sent from my iPhone
  • 4.  RE: ap 92 radio is not turning on and due not able to configure ap please help power light is blinking
    Posted Feb 07, 2015 01:21 PM
    are you sure you bought an IAP-92? and you haven't gotten a AP-92. look at the label at the back, when it says AP-92 you won't get an instant SSID, but need a controller to get it to work.
    or return it to your vendor and get an IAP.
    btw: why AP-92, these are out of sale since end of last year.
