can broadcast diffenrence ssid on each mesh instant AP ?
  • 1.  can broadcast diffenrence ssid on each mesh instant AP ?
    Posted Sep 19, 2012 09:45 PM
    have everyone know  instant AP105 can broadcast difference ssid on each AP during mesh ?
    example :
    AP1 (master)   -broadcast ssid - guest
    AP2 (slave)- broadcast ssid - guest1
    AP3 (slave)-broadcast ssid - guest2
  • 2.  RE: can broadcast diffenrence ssid on each mesh instant AP ?
    Posted Sep 20, 2012 01:17 AM
    All AP's in one Instant Group will advertise the same SSIDs.  You would need to have two separate groups.
  • 3.  RE: can broadcast diffenrence ssid on each mesh instant AP ?
    Posted Sep 26, 2012 08:26 AM
    two separate groups meaning at  difference network segment ?
    have any guideline, to do the group was mention ?
  • 4.  RE: can broadcast diffenrence ssid on each mesh instant AP ?
    Posted Sep 26, 2012 09:48 AM
    If all three IAPs are in the same Vlan they are in the same "Group".  The Virtual Controller (VC) is the Master of the group and pushes a copy of its' config to members of the group.  As such, if you have three SSIDs configured on the VC all three IAPs will advertise the three SSIDs.
    The only way to change this is to have three separate VCs -- each configured with only one SSID.
    To have three separate VCs you have two choices:
    1. They need to be connected, via Ethernet, to their own separate Vlans.
    2.  Alternatively, they could all be in the same vlan (wired via Eth); however, you must enable "Standalone Mode" on each of the IAPs so they all come up as their own VC.
    They will not be able to connect via Mesh as they will, again, be in one group.
    For more information please download the IAP 6.1.3.4_3.1.0.0 User's Guide - Ch.6 - Managing IAPs.
