enable only 80Mhz channels and specific MCS
  • 1.  enable only 80Mhz channels and specific MCS
    Posted Mar 02, 2016 10:32 AM
    I'm using Aruba Intant 225 AP and for testing purpose I would know if there is some way to enable only 80Mhz channel bonding on 5GHz band and how to do it.
    I would also know if I can configure specific MCS on 5Ghz, it's for testing purpose.
    Thank you
  • 2.  RE: enable only 80Mhz channels and specific MCS
    Posted Mar 04, 2016 03:28 PM
    All wifi needs legacy rates for management traffic, so you cannot exclude them, no.
  • 3.  RE: enable only 80Mhz channels and specific MCS
    Posted Mar 18, 2016 05:04 AM
    Hi joseph,
    I'm using IAP 225 with instant version 6.4.3.4 and I have seen that this release supports MCS 0-9 configuration for each stream, with commands:
       supported-mcs-set and vht-support-mcs-map  in a wlan profile
    The question is that I have configured MCS 2 or 3 for each one of three streams, but I don't see any changes at wlan profile configuration, the command is not shown at config.
    Is there some way to check for each stream which valid MCS is available??.
    Could also check is a client 11ac is using 20, 40 or 80 Mhz channel??.
    Thank you
  • 4.  RE: enable only 80Mhz channels and specific MCS
    Posted Mar 18, 2016 05:27 AM
