firewall settings for client isolation
What are the firewall settings for client isolation that actuaqlly work?
I've tried a mix of a few and the other clients still can see eachother.
I'm creating a new vlan and I need the clients to be completely isolated within that vlan.
Re: firewall settings for client isolation
You can do it at the virtual AP or global level.
Tim
Tim Cappalli | Aruba Security
Super Contributor I
You would want to use deny inter user bridging.
ACDX #419 | ACMP |
Can I use it on a single SSID or is it global?
I only want it on ONE SSID and not the other two
Yes, like I said, per virtual-ap (SSID) or globally.
Tim
How do you do that in the UI for just one SSID?
Valued Contributor II
Hi Friend,
You can enable " Deny Inter User Traffic" on VAP means we are enabling this per SSID basis.
Here is the method to enable it.
Hope got your answer.
Please feel free for any further query on this.
Cheers,
Venu Puduchery,
Is that airwave or the hardware controller?
Such option is not on the "instant" RAP109. My UI doesn't even look like that.
I see an option but it's GLOBAL and I want only one SSID VLAN (5) to isolate client traffic and not ALL  SSID VLANs.
Here's how I have it
SSID1:VLAN10=Main unrestricted VLAN for internal
SSID2:VLAN3=Guests and mobile devices
SSID3:VLAN5=Client systems that need web only access for software update and antivirus definitions. <<I want THIS one to have client isolation]
I only want the client isolation on SSID:VLAN5 and NOT the other SSID:VLANs
make your rules for that ssid to be like this.
which should achieve the client isolation for that ssid.
ACCP, ACCX #817, ACMP, ACMX #294
You need to do it at the CLI on Instant.
http://www.arubanetworks.com/techdocs/Instant_41_Mobile/Advanced/Content/CLI_commands/wlan%20ssid-profile.htm?SearchType=Stem
Tim
