iAP 93 Login problem after changing admin password
  • 1.  iAP 93 Login problem after changing admin password
    Posted Apr 17, 2012 05:00 AM
    I have 5 iAP 93.  After configuring them and changing the admin password,
    I can't login to the Administration page with the changed password.
    Got to do a hard reset for every AP.
    Thought it was a typo mistake but had reconfigure the AP thrice to confirm the problem.
    Anyone had this problem?
  • 2.  RE: iAP 93 Login problem after changing admin password
    Posted Apr 17, 2012 05:30 AM
    Did you try to login with two different browsers to make sure you don't get locked out?
  • 3.  RE: iAP 93 Login problem after changing admin password
    Posted Apr 17, 2012 08:07 AM
    Also,
    Are you using any strange characters in the password? Try just using something basic like password123, just to test.
