Occasional Contributor I
iapo-103 slow wifi connection
I have 3 iap-103's. my laptop has a dual band 2x2 wifi card. If i make a connection on the 5Ghz it shows it is connected with 300mbps.
When i do a speedtest it only reach arround 87mbps.
How can i make the wifi faster? i think i should be able to get around 150mbps.
I hope someone can help me.
Danny
Re: iapo-103 slow wifi connection
If your laptop is the only device on that SSID, you are not broadcasting any other SSIDs, and there is no broadcast traffic on that subnet, you can possibly get to 150.  Otherwise, you would have to remove all clients from that SSID on that channel and enable "broadcast filter arp" on that SSID under advanced to possibly get to 150.
This is allready configured. i just don't get over the 90mbps.
Anything else i can configure?
Danny
What are you using for a speedway? How many SSIDs are you broadcasting?
Hi What do you mean with speedway? The internet connection? that is a 300mb connection.
I have 2 ssid's 1 for 2.4Ghz and 1 for 5Ghz.
Danny
with the same laptop at my office it is also connected to the wifi and here i get a download speed of 152mbps.
So it is not the hardware in the laptop.
What is the access point model that you have at your office?
Thats a different brand. CIsco.
What model? The AP-103 is not a top of the line AP.
Ok so the iap 103 cannot go above 90mbps?
