instant rap-3wn not working
  • 1.  instant rap-3wn not working
    Posted May 30, 2014 09:53 AM
    I have an instant ap rap-3wn.  I am using it for home use and have done a reset but only see an amber wlan light and no "instant" ssid.  I have tried connecting wired to see if I can obtain ip from any of the E(X) ports but dont get anything.  Is there a default wired ip I can connect to?  What else can be done?
  • 2.  RE: instant rap-3wn not working
    Posted May 30, 2014 09:57 AM
    Is its E0 port connected to an upstream switch or router that can give out an IP address via DHCP?
  • 3.  RE: instant rap-3wn not working
    Posted May 30, 2014 10:03 AM
    I'm trying to manage the device being that wlan is amber.  If i connect it to my broadband and it gets an IP I don't think it will allow me to manage the device being that this is Untrust no?
  • 4.  RE: instant rap-3wn not working
    Posted May 30, 2014 10:06 AM
    If it can get an IP address through its E0 port, it should broadcast the instant SSID.
  • 5.  RE: instant rap-3wn not working
    Posted May 30, 2014 10:05 AM
    Yes i have made this mistake, it is not the stainless steel port., that is E2. It must be E0 as Yan mentioned.
  • 6.  RE: instant rap-3wn not working
    Posted May 30, 2014 10:19 AM
    It needs an IP before broadcasting the configuration SSID. You will be able to manage, I have a similar lab set-up.
    Connect to the Instant SSID then try to navagate to a page then you will be redirected to the login.
  • 7.  RE: instant rap-3wn not working
    Posted May 30, 2014 03:02 PM
    that did it thanks
