is it possible to mesh an IAP205 with an IAP105?
  • 1.  is it possible to mesh an IAP205 with an IAP105?
    Posted Nov 04, 2016 09:44 AM
    Is it possible to mesh an IAP205 with an IAP105?
    I appreocate that they would both need the same firmware and only one IAP has a cable connection.
    Thanks in advance.
  • 2.  RE: is it possible to mesh an IAP205 with an IAP105?
    Posted Nov 04, 2016 09:48 AM
    And they would need to be running 4.2.x.x firmware, is the last requirement.
    That software can be obtained here:  http://support.arubanetworks.com/LifetimeWarrantySoftware/tabid/121/DMXModule/661/Default.aspx?EntryId=20375
