Contributor I
kindly help i want to make LACP between aruba s3500 and s1500 also between s3500 and s2500.
kindly the steps how to make it.
thanks
Re: kindly help i want to make LACP between aruba s3500 and s1500 also between s3500 and s2500.
Contributor I
I already do this configuration on the s3500
 interface-profile lacp-profile BULDING9
 group id 9
no interface gigaethernet 0/0/21  #to remove qos profile
no interface gigaethernet 0/0/22
on the otherside s1500
 group id 1
no interface gigaethernet 0/1/0
no interface gigaethernet 0/1/1
but the connection down.. any advice
Do you have a switching profile tied to your port-channel?
Tim
Tim Cappalli | Aruba Security
Contributor I
first on s3500 i made lacp between s3500 and milestone server which i have made teaming on it and it success .
no switching profile i tried
You have to have a switching profile on your port-channel. This is how the VLAN(s) get assigned.
Tim
Contributor I
kindly could you send me the commands to make switching profile
thanks for your help :)
