Contributor II
more than one virtual controller on the same vlan?
If you are using IAPs on a virtual controller configuration, Could I have severals virtual controllers in the same vlan? And if it posible..Do you recommend it?
I´m not sure if it possible but I think that it´s not a good practise, I wolud like have a management vlan for each virtual controller, but I need confirm this information.
Regrads!!!
EF
Re: more than one virtual controller on the same vlan?
Is not possible
Thank you
Victor Fabian
Lead Mobility Architect
