problem with aruba central
Hi, i have a problem with the aruba central : it shows me that my APs are down (it actually can't get any information from them) but my APs are up and i'm connected to the wifi throw them.
I can ping the central aruba from the APs.
does anyone have such problem?
Valued Contributor II
Re: problem with aruba central
Hi Friend,
It seems, your cloud lisence is expired ( we need to verify it in the status portal with your registered email id ).
check with your partner and get activated.
Cheers,
Venu Puduchery,
It's not a problem with the license because it expires in 2015. I checked the firewall : there is no drop of the packets going to the central aruba.
The license is not expired.
[cid:image001.jpg@01D01884.76265E00]
Reagrds,
[net]
Julien Brochet
Consultant
Mob. +33 6 19 82 38 11
Tel. +33 1 46 48 26 14
julien.brochet@netxp.fr
NetXP - 159 rue de Silly, 92100 Boulogne-Billancourt
Ok,
were they mapped to your unique account ( Folder with your account name) or still in default folder ?
some times, if the communication between Aruba central and Activate is not in sync ( Order entry details) this situation will arise.
You can open a ticket with the TAC and get it resolved.
for you ref :
Please feel free to come back on the same if it is not fixed.
Cheers,
Venu Puduchery,
