Forum Français
Re: How To setup Prefered MASTER VC with AIRWAVE
Hi alagoutte,
     it is better to use english interface for AirWave ;-)
Is it possible to use English interface for AirWave even when the country code is set to a non-English country?
I see there are two options in AirWave related to the regulatory domain. The first one is in Groups > Basic > Regulatory Domain
The second one is in Groups > Instant Config > System
Are these two options related? When changing one of them the other is also changed? Because I understand the country code (2nd option) is related to the regulatory domain (1st option).
Julián
fjulianom@hotmail.com wrote:
Hi alagoutte,
Hi Julian,
Yes, you can use English interface for AirWave with a another Country Code !
ACMP 6.4 / ACMX #107 / ACCP 6.5
Hi alagoutte,
OK, but how can I set the language?
Julian
Where is the option to set the language in AirWave?
Julián
Yes, when you connect to AirWave, you can choice the language
Hahaha, so easy that I didn't notice this option when logging in.
Many thanks,
Julián
Many thanks,
Julián
:-D
Missing the settings when we are connected... (like for IAP)
