- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
01-31-2018 09:59 AM
Hi
We using VSA attribute to affect adymamic VLAN when the user is autenticated
Is it possible to affect to the user a default VLAN if the autentication fail ?
We using IAP solution
Thanks for your help
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
Re: IAP solution 802.1x default VLAN with authentication failed
01-31-2018 10:44 AM
Sorry to reply in English.
Unfortunately, when there is a rejection, only a reject message is sent back via radius.
Colin Joseph
Aruba Customer Engineering
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
01-31-2018 10:48 AM
Envoyé de mon Galaxy A5 Orange OCWs
_________________________________________________________________________________________________________________________
Ce message et ses pieces jointes peuvent contenir des informations confidentielles ou privilegiees et ne doivent donc
pas etre diffuses, exploites ou copies sans autorisation. Si vous avez recu ce message par erreur, veuillez le signaler
a l'expediteur et le detruire ainsi que les pieces jointes. Les messages electroniques etant susceptibles d'alteration,
Orange decline toute responsabilite si ce message a ete altere, deforme ou falsifie. Merci.
This message and its attachments may contain confidential or privileged information that may be protected by law;
they should not be distributed, used or copied without authorisation.
If you have received this email in error, please notify the sender and delete this message and its attachments.
As emails may be altered, Orange is not liable for messages that have been modified, changed or falsified.
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
01-31-2018 11:50 AM
There is not a way to do that with 802.1x, unfortunately.
Colin Joseph
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
