Forum Indonesia
Regular Contributor I
Re: Arubapedia
I get the same 403 error, or if i try to access some specific pages it just spins and nothing loads.
Could someone for who it is actually working provide the link they are using? Perhaps there is a specific URL which is working?
_ELiasz
ACDX, ACCP, CISSP, CWNA
Re: Arubapedia
I have the same problem after login:
You don't have permission to access / on this server.
Additionally, a 403 Forbidden error was encountered while trying to use an ErrorDocument to handle the request.
I tried different browsers and cleared cache but is did not help.
Re: Arubapedia
I am getting the same error message here...
Occasional Contributor I
Re: Arubapedia
You must access Arubapedia through this link:
https://partner.hpe.com/group/upp-aruba/arubapedia
Re: Arubapedia
Hai Gant,
Yes it's work. Thank you very much
Rimy
Thank you,
Rimy
MVP
Re: Arubapedia
This has post has been labeled as the solution but I'm seriously tempted to remove that classification.
Yes it works, but seriously, how can HPE/Aruba defend this?
Compare these 'procedures':
pre-hpe:
- goto afp.arubanetworks.com
- logon, done
post-hpe:
- goto https://partner.hpe.com/
- log off if you were logged on (there's no obvious link once you've logged on, only logging on redirects you)
- sign in again
- browse to "My Sites", select Partner Ready for Networking
- on the new site browse to "Resources", seclect Arubapedia
- on the new site, click "Go"
- bypass the security issues due to faulty certificate. Firefox allows this, chrome might not.
How is this considered acceptable even? Why change the first procedure everybody knew and loved and replace it with the current mess?
Sure, we can use the new direct url mentioned abouve, but that's one is hard to remember so would have to be bookmarked.
Koen (ACMX #351 | ACDX #547 | ACCP)
