Here is the latest Aruba Visio Stencil Library. I will update this article when another is released.
I'm going to jump on the necro bandwagon here. This stencil download DOES NOT contain ANY of the stencils shown in the preview image above the "Comments" and "Views" counters near the top of the thread.I can zoom in on the image and SEE the S3500-48P stencils that I need. But they are NOWHERE in the downloaded file.
What's going on here? Can we get some assistance with this or what? Have not enough people asked?
I am looking for stencils for aruba IAP 305
This post is 3 years old. I am looking for stencils for aruba IAP 367 and IAP 365. Also looking for 5406 R switches.
I hope someone reads these posts....
We need up to date libraries for current devices.
In Visio Pro 2016, all I see are generic looking outline drawings. That just won't do for a technical drawing.
I went to Visio Cafe and found actual Aruba networking switch visio stencils listed under the HPE-Networking section.
http://www.visiocafe.com/hpe.htm
The file is HPE-Networking.zip . They are listed by series, 3xxx-switches, 5xxx-switches, etc.
Hope that helps.
Will there be an updated stencil pack similar to the older stencil pack? The newer stencil pack works well for presentation slides, but a more realistic stencil would be preferred for technical documentation. Curious if that is something that may become available. Thank you.
Hello everyone,
I just downloaded the file, unzipped it and it works great (I mean the one on the first post of this thread). Thank you so much!
You can find the 3200 and pretty much anything else from the 7200 controllers and prior in this link:
https://support.arubanetworks.com/ToolsResources/tabid/76/DMXModule/514/EntryId/1649/Default.aspx
Jamie, I downloaded the zip file and cant even open it. Is this still valid? I am looking for antenna stencils for a customer.
Any luck on the 3200 controller stencils? Could really use them.
Let me see if I can round these up product stencils up.
thanks Jamie for the link. However, I couldn't find 3200 controller stencil. Can you please upload that too?
Sorry for the delay on updating the post we were having some unique issues with the stencils. Please give it another try and let us know how it goes.
May I know where the vss file is located? Thanks
same here for me
SAME exact experience on my end as others have reported. This Visio Stencil does not work. Aruba needs to engage and get us a good template.
That does not work which is why I have posted here
Hi all. To open this file, I create a new drawing, then in the stencils window, go to "More Shapes" and select "Open Stencil". It's worked for me on Visio 2010 and another user that was using a newer version. Hope this helps!
Any update on these Visio Stencils?
Is anyone from Aruba following this who can respond
Same issue
when I open the files there is nothing in them. I am using Visio version 14.0.7147 is the stencil compatible with this version or is there some trick to opening the collection of files?
