Frequent Contributor II
BL location beacon in 325 APs
[Not sure I'm posting on right board...]
So we turned on the beacon on one of our 325s... but when I tried to identify it with an iOS beacon app (Proximity Events), I wasn't able to find the UUID. Would I find that somewhere within the Controller, or does a different software control the beacon functionality?
Re: BL location beacon in 325 APs
Russell,
Check on the controller
#show ap debug ble-table ap-name <name> to display the beacons table
Pavan
Pavan
If my post address your queries, give kudos and accept as solution!
Pavan,
Apologize for asking an elementary question, but you would run that from Diagnostics/General/SSH Terminal, correct?
I'm clarifying because I don't believe my permission level allows shell access. (I get:
      Note:
      Please refresh the page to re-connect
      Public key authentication is not supported
      For security purposes, the user needs to re-enter the password
Is there no other way to get the BLE UUID?
We need to have shell access to APs to run those command. I dont think we have anyother way to check the beacon table list.
Pavan
Pavan
OK, I'll see if I can have someone else run the command.
Let me ask you, Pavan, if I have the AP's BLE mode set to "beaconing" will I need to do anything else in order to pair a device with the beacon?
I keep reading about "the Meridian app" but not sure where that is accessed from.
AP 325 is inbuilt beacon (which acts as indiviudal beacon) when configured with meridian details it start sending the beacon info to controller and to meridian cloud. If it is IAP then it will send data directly to meridian cloud.
AP325>Controller>Meridian Cloud
IAP30x >Meridian Cloud
If have you battery powered beacon and want to manage then you need USB power beacon plug in to APs.
We have meridian cloud (edit.meridianapps.com) where you could create iOS and Android apps that provide your visitors turn-by-turn directions, location and time-based push notifications, and other location-based services.
If you want to create account , please check with your Aruba accounts team, who could help you in getting account in meridian.
Pavan
Pavan
Pavan, does a Meridian account something that involves additional licensing fees?
We have different types of meridian subscriptions available, if you are looking for a trail I believe it will be valid for 3months (not sure exactly) and need to buy for full subscription.
Please check with your accounts team for more details.
Pavan
Pavan
I do not have the budget to pay for additional features.
So, just want to clarify: even if I have ble op mode set to "beaconing," that alone will not turn the ble beacon on?
(I have identified the beacon UUID #.)
Could you let me know why you want to enable beacon if you are not using meridian?
Pavan
Pavan
