MVP
How ALE Works?
[ Edited ]
Okay i understand that you need airwave so the ALE can work properly as it need to fetch the floor plans from somehwere...
Now does the ALE is the one that talks for example with MEredien server to send the Location information and all that?
Or its the one that would talk with a ragapa solution so it knows the location information that they need to send an advertisement?
Can someone talk me a little more about it ?:)
Cheers
Carlos
Alternetworks Corp
