Tutorial by: NightShade1
Hello everyone, today i did my second memory upgrade to 1gig of a 3200 so i decided to do a manual of this second one!
Let Start!!
The first thing you need to do is yes of course backing up your controller!
The secondt thing you need to do is rebooting the controller and when its booting up you need to press any key example enter enter enter :)
Until you get in the cpboot like this:
CPBoot 1.2.0.0 (build 20527)
Built: 2009-01-20 at 18:55:40
DRAM: Operating at 533 MHz
DRAM: Channel 0: 512 MB
DRAM: Channel 2: 0 MB
DRAM: Total = 512 MB
POST: Memory test: Physical 0 - 0x10000000 - quick test
Memory test: Physical 0x10000000 - 0x20000000 - quick test
PASS
CPU: XLR508 rev. C4 Clock: 800MHz
Board: A3200
CPLD: rev: 1.2
SMP: All 8 cpus successfully started
Boot: Primary bootflash partition
POST2: OK
Net: xlr_gmac0 xlr_gmac1 xlr_gmac2 xlr_gmac3
IDE: Bus 0: OK
Device 0: Model: CF 512MB Firm: 20080112 Ser#: 2010B 0000141896
Type: Removable Hard Disk
Capacity: 502.0 MB = 0.4 GB (1028160 x 512)
Hit any key to stop autoboot: 0
cpboot>
cpboot>
cpboot>
cpboot>
cpboot>
As you see DRAM says its 512mb
When you are in the cpboot you need to issue the next command: eye_finder
Like this:
cpboot> eye_finder
Erasing #
Erased 1 sectors
Writing ################
cpboot>
After this you need to turn off or disconnect the controller
Take the
Now open the wireless controller to change the Memory, which is located where the red box is
You take that memory off and put the memory you bough in that slot.
Now you close the Wireless controller and turn it on again and let the normal booting goes...
You will see this
***** Running DRAM Eye-Finder *****
.........DRAM: Channel 0: 1024 MB
DRAM: Total = 1024 MB
Memory test: Physical 0x10000000 - 0x40000000 - quick test
PASS
Board: A3200
CPLD: rev: 1.2
POST2: OK
Saving eye-finder results to flash...
Erasing #
Erased 1 sectors
Saving eye-finder results in secondary bank...
Erasing #
Erased 1 sectors
Reselecting primary flash bank.
IDE: Bus 0: OK
Loading image 0:0########################################
You will see that the eye finder will work there for like1 or 2 minutes so be patient!
You also will notice that the DRAM now its 1024MB instead of 512MB, so if you see this then you did a good job, you are done! :)
Cheers
Carlos
[Mod note: edited title for readability]
