Features and Enhancements:- Monitoring support of Trapeze devices. - Controllers and thin AP monitoring. - Support for OEM versions from Nortel, 3Com and Enterasys.- Monitoring of Meru devices. - Controller and thin AP monitoring.- Network Usage and Device Summary Reports are now supported on Master Console.- QuickView now uses flash.- New Site Survey.- AMP events and audit log messages are forwarded to an external syslog server.- C compiler is no longer required to install AMP.- Monitor channel asynchronously on APs using SNMP.Bug Fixes:- IOS fixes. - No more telnet errors while trying to verify config on IOS Aps which are rebooted after a config push. - Credentials are not updated when ssh session times out while communicating to IOS devices.- SNMP loop errors. - AMP does not have issues with fetching data from snmp tables, some of the errors seen while fetching. configuration on Airespace devices.- AMP can configure WEP on Proxim devices.
