6.2 Known Issues
6.2.1 Known Issues:
RHEL5.3: Currently, attempts to run AMP on 5.3 have not worked. This is still in the testing stage.
VisualRF: When exporting floor plans from an Aruba or Alcatel-Lucent controller, all the floor plans must be included in a SINGLE exported file. If the user tries to break up the floor plans/buildings/campuses into separate exported files, it could cause a mismatch in the number of APs being placed on the floor plans.
VisualRF: Import from AOS has a conversion error for AOS version 2.5, causing partial or incomplete import.
6.2.2 Known Issues:
AMP: Applying changes to other groups will fail if one of the changes is the group name. This will be fixed in the next maintenance release.
VisualRF: Import from AOS version 2.5 may not display the correct AP count, contact support@airwave.com for a workaround (DE10559).
Version history
Revision #:
1 of 1
Last update:
‎06-09-2014 09:37 AM
Updated by:
Labels (1)
