If the upgrade fails in STEP 3 with the following error:. . .Use of uninitialized value in addition (+) at /root/svn/mercury/lib/perl/Mercury/MigrateRRD/CheckAWRRDMigrationSpace.pm line 53.The following RRD files have values which are too large:/var/airwave/rrd/ap_bandwidth/537make: *** [check_awrrd_migration_values] Error 1Upgrade aborted. Please contact AirWave Support.1-866-WiFi-AMP or support@airwave.comGoodbyeRun the following command on the AMP command line:# perl -MMercury::MigrateRRD::PurgeSpikes -e "Mercury::MigrateRRD::PurgeSpikes->go"After this command completes, run the upgrade command again.Example:# start_amp_upgrade -v 7.0.1If the upgrade still does not complete successfully, please contact Customer Support for further assistance.
