Issue: APs not showing up in VisualRF Provisioning dialog
VisualRF Auth timer is set to 15 minutes. So it takes 15 minutes for VisualRF to discover new APs from AMP.Browser Flash also caches the floor plan. If you can't find APS to Add to the site then you need to hit F5 to referesh the page.Note: VisualRF deletes APs if they are down after 5 x (Sync Timer)
