Skip to main content (Press Enter).
Register | Sign in
Skip auxiliary navigation (Press Enter).
Skip main navigation (Press Enter).
Toggle navigation
Discussion
Support
Aruba Documentation Portal
Aruba Support Knowledge Base
Community Learning
News
ACEX Hall of Fame
MVP Overview
Tech Corners
Search
View Entry
Monitoring, Management & Location Tracking
Community Home
Discussion
0
Library
1K
Members
7
last person joined: one year ago
Articles relating to existing and legacy HPE Aruba Networking products and solutions including AirWave, Meridian Apps, ALE, Central / HPE Aruba Networking Central, and UXI / HPE Aruba Networking User Experience Insight
Back to Library
Difference between ?wms clean-db? and ?wms reinit-db?
0
Kudos
Jul 07, 2014 01:23 AM
vikrams@aruba
It is important and vital to understand the difference between the two wms commands:
"wms clean-db" and "wms reinit-db" in order not to lose valuable data that could have cost many man-hours to complete.
wms clean-db:
This command deletes the wms data stored in the various mysql tables and does not affect the sql table structures or the rf-plan data.
wms reinit-db:
This command deletes the wipes out the wms data, the rf-plan data and rebuilds the the sql table structures.
Issuing this command without a prior export of the rf-plan would result in an unrecoverable loss of such data that includes floor plans per floor and building as well as position of AP's on each floor plan.
If there is a requirement to reinitialize the wms database, be sure to export the rf-plan building by building (if extensive) so that the re-import of such data could be done without failures caused by large file sizes.
Once the export is successful, the "wms reinit-db" command could be executed.
Statistics
0 Favorited
0 Files
0 Shares
0 Downloads
Related Entries and Links
No Related Resource entered.
Privacy policy
Terms of service
Site Map
Legal
© Copyright 2024 Hewlett Packard Enterprise Development LP
All Rights Reserved.
Powered by Higher Logic
