Q: I'm trying to create a VLAN but the VLAN Edit page has this:
"Enable VLAN Tagging: Airespace, Colubris, Symbol only" (yes/no)
Does that mean that AMP only supports VLANs on those AP types?
A: No, it just means that this particilar setting only needs to be edited for those. For many other APs, including Proxim APs and the HP 420, you can define an untagged VLAN by setting it as the Native VLAN on the VLANs List page.
