After getting to update_db.pl, the migration can fail with an error like this:Use of uninitialized value $args[0] in join or string at /usr/local/airwave/lib/perl/Mercury/DB/Q.pm line 191, <INFO> line 8.ERROR: null value in column "poll_period_client_data" violates not-null constraint: update ap_group set poll_period_client_data=? where ap_group.id=? ( 12) at /usr/local/airwave/lib/perl/Mercury/DB/Q.pm line 1916.1.1 will have a fix. Until that's available you can contact support for help or you can run these 3 commands:# echo "update ap_group set poll_period_dot11_counters = 0 where poll_period_up_down=1800 and poll_period_dot11_counters=1800 and poll_period_mesh_data=1800 and poll_period_client_data=1800" | db# root; make# echo "update ap_group set poll_period_dot11_counters = 1800 where poll_period_dot11_counters=0 and poll_period_up_down=1800 " | dbAfter getting to update_db.pl, the migration can fail with an error like this:Use of uninitialized value $args[0] in join or string at /usr/local/airwave/lib/perl/Mercury/DB/Q.pm line 191, <INFO> line 8.ERROR: null value in column "poll_period_client_data" violates not-null constraint: update ap_group set poll_period_client_data=? where ap_group.id=? ( 12) at /usr/local/airwave/lib/perl/Mercury/DB/Q.pm line 1916.1.1 will have a fix. Until that's available you can contact support for help or you can run these 3 commands:# echo "update ap_group set poll_period_dot11_counters = 0 where poll_period_up_down=1800 and poll_period_dot11_counters=1800 and poll_period_mesh_data=1800 and poll_period_client_data=1800" | db# root; make# echo "update ap_group set poll_period_dot11_counters = 1800 where poll_period_dot11_counters=0 and poll_period_up_down=1800 " | dbAfter getting to update_db.pl, the migration can fail with an error like this:Use of uninitialized value $args[0] in join or string at /usr/local/airwave/lib/perl/Mercury/DB/Q.pm line 191, <INFO> line 8.ERROR: null value in column "poll_period_client_data" violates not-null constraint: update ap_group set poll_period_client_data=? where ap_group.id=? ( 12) at /usr/local/airwave/lib/perl/Mercury/DB/Q.pm line 1916.1.1 will have a fix. Until that's available you can contact support for help or you can run these 3 commands:# echo "update ap_group set poll_period_dot11_counters = 0 where poll_period_up_down=1800 and poll_period_dot11_counters=1800 and poll_period_mesh_data=1800 and poll_period_client_data=1800" | db# root; make# echo "update ap_group set poll_period_dot11_counters = 1800 where poll_period_dot11_counters=0 and poll_period_up_down=1800 " | db
