If you want to copy RAPIDS rules from one AMP to another, you first dump the rules from the one AMP and then use the rapids_classification_rule script generated by the dump to restore them onto the target AMP.- You use the generic_dump command to dump one or all RAPIDS classification rules. - RAPIDS rules reside in the rapids_classification_rule table. - You can dump all the rules using the --all flag.- You can dump one particular rule using the --id flag followed by the rule's ID number - See instructions below for obtaining a rule's ID number.The dump will be written to /tmp/rapids_classification_rule. The resulting file is actually a perl script that you will use to restore the RAPIDS rule(s) you dumped.General usage:# generic_dump --table <table> [ --id <rule_ID> | --all]Examples:# generic_dump --table rapids_classification_rule --alloutput file is /tmp/rapids_classification_rule# generic_dump --table rapids_classification_rule --id 1output file is /tmp/rapids_classification_rule(NOTE: the --all flag does not work with all tables, so it is not included in the command's usage help.)Copy the rapids_classification_rule file you created to the AMP where you want to restore the rule(s). (We recommend that you copy it to the /var/airwave/custom directory.) The file is a perl script that you run as follows:# perl /var/airwave/custom/rapids_classification_ruleNOTE: The script will not replace nor overwrite existing rules. - Restored rules will be added to any rules already existing on the server. - If you restore a rule that has the same name as a rule already on the server--whether the rule is different or identical-- both rules will appear.To obtain the ID number of a RAPIDS rule:- Go to the RAPIDS > Rules page- Find the rule that you want the ID for- Hover the mouse over the pencil icon next to the rule- At the bottom of the browser window you should see the corresponding URL- At the end of the URL you will see ....&id=[ID]. Example:. https://my.amp.com/nf/rapids_rules?edit=1&id=6. The rule ID in this case is 6.
