AMP only allows you to delete empty folders that have no sub-folders. You can delete an empty folder by going to the APs/Devices > List page and choosing your empty folder from the drop down list (see screen shots attached). Then at the bottom of the page click the Delete this Folder button.A couple of conditions other than a Folder not being empty or having sub-folders can prevent the Delete button from showing up:1. The Folder contains Ignored devices.Move the devices to another Folder, then delete the Folder:- Go to APs/Devices > Ignored page- Check all devices in Folder to be deleted- <Unignore>- Go to APs/Devices > List page- click on the Modify Devices link- Check all devices in Folder to be deleted- Using options below list: Move to Folder <select another Folder from drop down list>- <Move>- <Apply Changes Now>If you want to Ignore the devices again:- click on the Modify Devices link- Check all devices to be Ignored- Using options below list: <Ignore>Delete the Folder using the instructions at the top of this article.2. A Role has been defined with this Folder specified as its Top Folder.Check the Top Folder column on the AMP Setup > Roles page.Either delete the Role or change its Top Folder (click on the pencil icon next to the Role name to Edit the Role definition).
