There would always be a requirement to add physical drives to an existing ESXi Server.
This article explains the steps needed to add the physical disk drive to the ESXi Server.
4. Connect the communications cable to the proper port on the server board, in this case a SATA communications port.
5. Upon confirmation of all cables and connectors being properly attached, Boot the ESXi Server.
6. Login to the vSphere client application to verify the added Physical drive.
Click on the top level IP for the VM, select the ‘Summary’ tab and we now see that there are two physical disks installed in the ESXi Server as per below
