Monitoring, Management & Location Tracking
How to enable/disable view device credentials option on Airwave
MVP
MVP
On Airwave under Manage page for a device we have an hyperlink to "view device credentials" which allow us to view the SNMP/Telnet credentials provided for a device. Sometimes due to security challenges we would have to disable the link so that it cant be viewed by other users who logs into Airwave.
We have a field in Seas_config table in db which have a column called hide_secrets which would allow us to set a value for enabling or disabling this hyper link.
To disable the hyperlink you can execute the below command from Airwave CLI,
# dbc "update seas_config set hide_secrets = 1;"
To enable the hyperlink we can execute the below command,
# dbc "update seas_config set hide_secrets = 0;"
To verify we can login to Airwave GUI and check whether the link. When its disabled we wont find the link anymore as in the screen shot below,
Version history
Revision #:
2 of 2
Last update:
‎12-19-2016 10:12 AM
Updated by:
Labels (1)
Contributors
