How can we get Airwave license key from Airwave CLI when Airwave web interface is down?
Prior to 8.0 series we had the license key stored on Airwave under /var/airwave/license/license.txt. However, from 8.0.x onwards its moved. We can you use the below command from Airwave CLI to get the license key from Airwave Database,
# dbc 'select raw_license from license;'
