Symptoms :
This can be done usingkill -9 $(pidof Daemon:: ConfigVerifier)
check above logs to see if AMP is trying to actually push the configuration desired
Try to push the config again
dbc “select count (*) from new_config”Delete themdbc “delete from new_config” Once done try to push the config again and see if that helps
kill -9 $(pidof Daemon:: ConfigPusher)kill -9 $(pidof Daemon:: PartialConfigPusher)
