Environment :
When IAPs are managed by Airwave using IGC it is necessary to check if the new configuration / modified configuration is sent to IAP and also required to know if the configuration is accepted by Virtual Controller or not.
Once the configuration change is being applied Airwave will initiate configuration audit and post the mismatched configuration to the VC over https.We can review the configuration that VC receive from Airwave using the following method.Navigate to the VC Monitor page, from the drop down list "Run commands from VC" select "VC AMP Last Configuration Received" as shown in the following image.
Airwave will query the respective VC for the recently received configuration and will list the configuration lines that are sent from Airwave with it's status while it is applied.
