Environment : This applies to all versions of Airwave
It is not possible to import other MIBs into AirWave today. We have 2 options for adding switches that are not explicitly supported: First option: On the Device Setup -> Add page, add the device as type "Router/Switch". This will work for any switch that uses the standard MIBs. Second option: On the Device Setup -> Add page, add the device as type " universal device". AMP gets basic monitoring information from any device including switches, routers and APs whether or not they are supported devices. Entering SNMP credentials is optional. If no SNMP credentials are entered, AMP will provide ICMP monitoring of universal devices.
