Install Problems
Q: I just tried to install AMP and I don't think it worked. How can I tell?
A: AMP creates an install log at /tmp/amp-install.log. It's easy to see the last several events by tailing the log like this:
# tail /tmp/amp-install.log
Version history
Revision #:
1 of 1
Last update:
‎06-10-2014 03:10 PM
Updated by:
Labels (1)
