Problem:When the iptable service starts it ends up with the following error message:
FATAL: Module ip_tables not found.
'ptables-restore v1.4.7: iptables-restore: unable to initialize table 'filter
Error occurred at line: 1
Diagnostics:The way the single-quote that ought to follow the word filter
has migrated itself back to the start of the line makes me very suspicious that the rules file contains spurious ^M
characters at the ends of lines, and that iptables
is actually complaining that it can't initialise table 'filter^M'
- which it most certainly can't, there being no such table.
This non-printing (and thus hard to see) ^M
would have come from the first line of the file you quote above, if it was in fact *filter^M
SolutionThe easiest way to be sure is to edit the file with vi
in binary mode, vi -b /etc/sysconfig/iptables
(I'm assuming that's the file you're quoting above), and look for non-printing characters that shouldn't be there and remove them and save the file.
Then restart the iptables to resolve the issue.
[root@airwave mercury]# service iptables restart
iptables: Flushing firewall rules: [ OK ]
iptables: Setting chains to policy ACCEPT: nat filter [ OK ]
iptables: Unloading modules: [ OK ]
iptables: Applying firewall rules: [ OK ]
