To check which IP address is currently being used by AMP, run the following command:# dbc 'select ap_facing_amp_interface from seas_config;'To change the interface that AMP is using, run a command like this:# dbc "update seas_config set ap_facing_amp_interface = 'INTERFACE_NUM';"Example:# dbc "update seas_config set ap_facing_amp_interface = 'eth1';"-OR-# dbc "update seas_config set ap_facing_amp_interface = 'bond0';"For a more detailed description of this topic please refer to the Knowledge Base article:Instructions for Setting up Ethernet Failover (bonded interface) on AMPhttp://kb.airwave.com/?sid=50140000000Mere
