running and also did not get the WEB console of AMP. So in such cases we have to restore the
default SSL certificate on AMP which was before
First we will delete the existing symbolic link files :
[root@localhost mercury]# rm -rf /etc/httpd/conf/ssl.crt/server.crt
[root@localhost mercury]# rm -rf /etc/httpd/conf/ssl.key/server.key
[root@localhost mercury]# rm -rf /etc/httpd/conf/ssl.pem
Create symbolic link with the default SSL cert and key file :
[root@localhost mercury]# ln -s /etc/pki/tls/certs/localhost.crt /etc/httpd/conf/ssl.crt/server.crt
[root@localhost mercury]# ln -s /etc/pki/tls/private/localhost.key /etc/httpd/conf/ssl.key/server.key
[root@localhost mercury]# cat>/etc/httpd/conf/ssl.pem /etc/pki/tls/certs/localhost.crt /etc/pki/tls/private/localhost.key
Finally, restarting pound should make the change successful.
[root@localhost mercury]# service pound restart
Stopping Pound: [ OK ]
Starting Pound: starting...
[ OK ]
After restarting pound, login to AMP web page and you should see AMP loading with default certificate.
