Unknown COM error occurred
Problem: "Unknown COM error occurred" in AWSP.
Solution: This is usually an indication of some kind of an environmental/setup problem. The most common cause is the wrong version of .NET. AWSP 5.0 and earlier require .NET 1.1. If you have any other versions you can:
1. Uninstall other versions of AWSP, and make sure that 1.1 is installed.
2. Reinstall AWSP.
In almost all cases, this will resolve the problem.
Version history
Revision #:
1 of 1
Last update:
‎06-06-2014 08:33 AM
Updated by:
Labels (1)
Contributors
