AirWave support will create a profile for you to connect to the Support Connection Server. You will be able to download the config for that profile like this: # get_support_config <Name_of_Profile> Once the unique config file has been downloaded you can start, stop, or check the status of the Support Connection with these commands: # service support_connection restart # service support_connection stop # service support_connection status Unless it's stopped with the stop command, it will remain open for 4 days.
