Prerequisites: Running AMP 7.x+ (i.e. 7.0.x, 7.1.x, 7.2.x).This is for resetting VisualRF back to installation default. Following these steps will erase all previous VisualRF data. Only use these steps if you wish to return to the installation state of default campus with default building and no floor plans.1. Disable VisualRF from the Web UIGo to VisualRFGo to Setup tabSet VisualRF Engine enabled to NOSave and Apply2. Clear the VisualRF data from the Command Line (PUTTY)Login to command line with root access userMake sure VisualRF is disabled:# ps auwwx | grep -i javaIf you get no return, or newline return, then VisualRF is completely stopped. If not, you can keep issuing psg java until you get no return. VisualRF typically takes 1-3 minutes to fully stop.Remove the VisualRF data from that directory:# rm -rf /var/airwave/data/# rm -rf /var/airwave/cache/Remove the VisualRF backup data from the database:# dbc 'drop table visualrf.configuration;'Logout of command line3. Re-enable VisualRF from the Web UIGo to VisualRFGo to Setup tabSet VisualRF Engine enabled to YESSave and ApplyWait for 4-5 minutesGo to VisualRF -> Floor Plans tab.You should see just default campus and 1 default building in that campus. Floor plan list should show 0 floor plans.
