Which are the supported MDM servers for Airwave?
Environment : An MDM server like SOTI MobiControl is added to Airwave to provide direct access to the MobiControl Web Console
As of Airwave 7.7.11 we only support SOTI MobiControl. We do not support any other MDM servers. This will hold true unless we mention it otherwise in the Release Notes for the newer versions.
The last version of SOTI MobiControl tested for support was v10. The minimum version of SOTI MobiControl required for integration is v8.0
Version history
Revision #:
1 of 1
Last update:
‎06-30-2014 04:08 AM
Updated by:
Labels (1)
Contributors
