***QUESTION***My upgrade is failing as follows:ALTER TABLE SET SET make[2]: *** [postgresql] Hangup make[1]: *** [src_install] Hangup make: *** [upgrade] Hangup What does this mean? How do I proceed?***SOLUTION***This meassage is usually generated when an SSH session terminates while the upgrade is still in progress.To complete the upgrade process run the following commands:# root (alias for: cd /root/svn/mercury)# makeIf the upgrade fails again and if you are seeing something like this:DB::Q->scalar must return exactly one value: got 0 rows, N/A cols at Mercury/Utility/Assert.pm line 45 3 ( Mercury/DB/Q.pm:55) ASSERT 2 (Mercury/MigrateDB/CheckInterfaceUIDs.pm:16) Mercury::DB::Q::scalar('Mercury::DB::Q', 'select version from seas_config') 1 ( -e: 1) Mercury::MigrateDB::CheckInterfaceUIDs::check('Mercury::MigrateDB::CheckInterfaceUIDs') make: *** [check_interface_uids] Error 2...see below for further steps. If you are not seeing the message above, try running the make command again:# makeIf the upgrade still does not complete successfully, please contact Support.----------------------------------------make: *** [check_interface_uids] Error 2----------------------------------------If you were upgrading from 6.x to 7.0 continue... If not, please contact Support. The likely cause of this message is:- During the upgrade process AMP updated the version number in the database;- The data has not been fully upgraded from the previous version- when you try to upgrade again AMP runs a check that is not valid for the version you are upgrading fromFirst, you will need to reset the version in the database to a pre-7.0 version. (IT DOES NOT matter what version you were actually on.)# dbc "update seas_config set version='6.4.1';"Then run the make command again:# makeIf the upgrade still does not complete successfully, please contact Support.
