Environment : All versions of Airwave
Large amount of traffic resulting in a network flood which eventually may result in a network down as well.
It would indicate a server infected with malware/virus
Reinstalling the server is sometimes the only option in this case.Ensure the new server has a complicated root password.Also, follow the best network security practices to protect the installed Airwave server.
Troubleshooting steps :1) Take a pcap on Airwave server and check the traffic pattern. We usually see a large number of packets destined to Internet on random ports like 17777,56789 etc2) Check netstat -anp and ps -efSample outputs :netstat -anpActive Internet connections (servers and established)Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name tcp 0 0 127.0.0.1:8558 0.0.0.0:* LISTEN 3432/perl tcp 0 0 127.0.0.1:8559 0.0.0.0:* LISTEN 3532/Daemon: tcp 0 0 127.0.0.1:9999 0.0.0.0:* LISTEN 3440/Daemon: tcp 0 0 0.0.0.0:111 0.0.0.0:* LISTEN 1342/rpcbind tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 3550/pound tcp 0 0 127.0.0.1:8560 0.0.0.0:* LISTEN 3532/Daemon: tcp 0 0 127.0.0.1:4369 0.0.0.0:* LISTEN 2190/epmd tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 1481/sshd tcp 0 0 127.0.0.1:5432 0.0.0.0:* LISTEN 1524/postmaster tcp 0 0 127.0.0.1:8569 0.0.0.0:* LISTEN 3597/Daemon: tcp 0 0 127.0.0.1:25 0.0.0.0:* LISTEN 1622/master tcp 0 0 127.0.0.1:8570 0.0.0.0:* LISTEN 3597/Daemon: tcp 0 0 0.0.0.0:443 0.0.0.0:* LISTEN 3550/pound tcp 0 0 127.0.0.1:6654 0.0.0.0:* LISTEN 3437/Daemon: tcp 0 0 127.0.0.1:43327 0.0.0.0:* LISTEN 3492/beam.smp tcp 0 0 127.0.0.1:6655 0.0.0.0:* LISTEN 3437/Daemon: tcp 0 0 127.0.0.1:7777 0.0.0.0:* LISTEN 3443/Daemon: tcp 0 0 127.0.0.1:5672 0.0.0.0:* LISTEN 3492/beam.smp tcp 0 0 127.0.0.1:8008 0.0.0.0:* LISTEN 2689/httpd_________tcp 0 0 127.0.0.1:7777 127.0.0.1:13342 ESTABLISHED 3443/Daemon: tcp 0 401 172.30.101.206:2493 115.231.17.9:56789 ESTABLISHED 13877/smarvtd tcp 0 401 172.30.101.206:2769 115.231.17.9:56789 ESTABLISHED 20979/smarvtd tcp 0 0 127.0.0.1:5672 127.0.0.1:29839 ESTABLISHED 3492/beam.smp tcp 0 0 127.0.0.1:7777 127.0.0.1:13296 ESTABLISHED 3443/Daemon: tcp 0 0 127.0.0.1:8558 127.0.0.1:3013 ESTABLISHED 3432/perl tcp 10422 0 127.0.0.1:30065 127.0.0.1:5672 ESTABLISHED 30309/Daemon: tcp 0 0 127.0.0.1:5672 127.0.0.1:48638 ESTABLISHED 3492/beam.smp tcp 0 0 127.0.0.1:7777 127.0.0.1:43835 ESTABLISHED 3443/Daemon: tcp 0 401 172.30.101.206:2632 115.231.17.9:56789 ESTABLISHED 12189/smarvtd tcp 0 401 172.30.101.206:2682 115.231.17.9:56789 ESTABLISHED 43296/smarvtd tcp 0 401 172.30.101.206:2568 115.231.17.9:56789 ESTABLISHED 8830/smarvtd tcp 0 401 172.30.101.206:2814 115.231.17.9:56789 ESTABLISHED 6015/smarvtd tcp 0 401 172.30.101.206:2535 115.231.17.9:56789 ESTABLISHED 35395/smarvtd truncated...[root@localhost mercury]# ps- -eadfroot 6283 1 0 Nov27 ? 00:01:51 /tmp/smarvtdroot 6459 1 0 05:00 ? 00:00:11 /tmp/smarvtdroot 6642 1 0 Nov12 ? 00:07:08 /tmp/smarvtdroot 6918 22957 0 Nov07 ? 00:00:00 [ps] <defunct>root 6987 1 0 Nov29 ? 00:01:06 /tmp/smarvtdroot 7163 1 0 Nov26 ? 00:02:20 /tmp/smarvtdroot 7175 1 0 Nov29 ? 00:01:13 /tmp/smarvtdpostfix 7396 1622 0 17:50 ? 00:00:00 local -t unixroot 7510 1 0 Nov24 ? 00:03:03 /tmp/smarvtdroot 7640 1 0 Nov27 ? 00:01:51 /tmp/smarvtdroot 7775 1 0 Nov19 ? 00:04:49 /tmp/smarvtdroot 8163 1 0 Nov29 ? 00:01:11 /tmp/smarvtdroot 8306 1 0 Nov08 ? 00:08:39 /tmp/smarvtdroot 8439 22968 0 Nov08 ? 00:00:00 [sh] <defunct>root 8528 1 0 Nov30 ? 00:00:45 /tmp/smarvtdroot 8555 1 0 Nov27 ? 00:02:05 /tmp/smarvtdapache 8576 3144 0 Nov24 ? 00:00:00 /opt/airwave/sbin/httpd______________________________________apache 8622 3144 0 Nov24 ? 00:00:01 /opt/airwave/sbin/httpd______________________________________apache 8623 3144 0 Nov24 ? 00:00:01 /opt/airwave/sbin/httpd______________________________________root 8750 1 0 Nov29 ? 00:01:02 /tmp/smarvtdroot 8830 1 0 Nov29 ? 00:01:24 /tmp/smarvtdapache 9061 1 0 Nov24 ? 00:00:00 awrrdtool [8576] -postfix 9154 1622 0 17:51 ? 00:00:00 bounce -z -t unix -upostfix 9159 1622 0 17:51 ? 00:00:00 local -t unixroot 9308 1 0 Nov21 ? 00:04:10 /tmp/smarvtdroot 9439 1 0 Nov28 ? 00:01:36 /tmp/smarvtdroot 9608 1 0 Dec01 ? 00:00:26 /tmp/smarvtdroot 9721 22958 0 Nov07 ? 00:00:00 [ps] <defunct>root 9855 1 0 Nov19 ? 00:04:34 /tmp/smarvtdroot 9896 1 0 Nov27 ? 00:01:51 /tmp/smarvtdroot 10141 1 0 Nov22 ? 00:03:42 /tmp/smarvtdroot 10225 22955 0 17:51 ? 00:00:00 /tmp/.sshdd1415277056postgres 10257 1524 0 Nov24 ? 00:00:00 postgres: airwave airwave [local] idle root 10786 22963 0 Nov07 ? 00:00:00 [sh] <defunct>root 10869 1481 0 17:52 ? 00:00:00 sshd: root@pts/0root 11008 1 0 Nov25 ? 00:02:38 /tmp/smarvtdroot 11055 1 0 Dec01 ? 00:00:20 /tmp/smarvtdroot 11078 22958 0 Nov08 ? 00:00:00 [ps] <defunct>root 11105 1 0 Nov24 ? 00:02:45 /tmp/smarvtdtruncated...In one of the environments we could see a large number of smarvtd processes running. smarvtd is a potential malware based on the references on the web. One of the useful links pointing towards the same is :http://lists.centos.org/pipermail/centos/2014-October/146566.html
