Solution :
Installing 7.2.1 and doing an immediate upgrade to 7.2.2 presents the user with an prompt indicating a modified file was detected and a dialog asking the user to contact AirWave support and whether or not they want to continue upgrading. The message looks like this:-------------------------------svn: Directory 'lib/perl/Mercury/AP/Aruba/AOS/XML/.svn' containing working copy admin area is missingWARNING: AMP contains patches or modifications to the codeThese changes are likely to be overwritten during the upgrade.For additional information please contact AirWave Wireless Support at:1-866-WiFi-AMP or support@airwave.com-------------------------------If you encounter this, you should go ahead and select yes to continue upgrading; this is not a serious error and can be safely ignored.
