Q: AMP won't start and I see a bunch of messages like this in the log:INIT: Id "sw" respawning too fast: disabled for 5 minutesA: The problem is that postgres isn't started. There are two things you should do:1. Get postgres started now:# service postgresql start2. Configure the OS to always start postgres when it boots up:# chkconfig postgresql on After you do that, you should see that postgres is set to "on" for runlevels 2-5 when you run this command:# chkconfig --list | grep postgreqlpostgresql 0:off 1:off 2:on 3:on 4:on 5:on 6:off
